ignition coil question
Jeff Kavanagh
Owen Sound, Ont., Canada
85' CJ7, straight 6, D300, All I know so far about he transmission is that it is a 5 speed manual. Still trying to learn what everything else is. lol
Jeff, One of those red wires does go to the ignition, and makes a few stops along the way. It also looks to be a bit large for an oem item, which is a good thing. The other is for a noise suppressor in the form of a capacitor, it is not necessary, but will smooth out the ignition from spikes. You could check for 6 volts at that positive coil terminal, with the key on just to check the ignition. You could also check a spark plug to see if it will light up. A further ignition check would be in the M.R. 252, factory service manual.
Do you have a tach?
That other red, POS(+) lead you speak of should go to the "I" terminal of your starter solenoid.
The wiring diagram for this is on page C-58 of FSM, MR-252
Do you have a tach?
No I don't have a tach.
I've ordered an FSM but it is on backorder. :(
Thanks again for your replies everyone. :notworthy:
That's the tach lead then.
Gert-Don't think so for the 6 cyl. :confused:
What year chart is that?
It does show you to be correct if it was an 8cly. That's why I ask the year for the diagram.
The capacitor lead on my '85 was a black wire and was attached to the coil mounting bracket.
    Best for votes
    on specific items
