Initial Timing Question
Az84cj7
AZ
84 cj7 Inline 6, mopar fuel injection , T5 trans, dana 300, Dana 44's
Im trying to set the initial timing on my buddies 84cj7 with the AMC 258 i6 / 4.2l . I know it needs to be at TDC. My question is what clock position does the oil pump need to be set at and where should number one be on the distributor cap. Thanks
The oil pump just has to line up with the distributer shaft, wherever it wants to be. I like the #1 to be where the vacuum advance diaphragm has the most range of movement without hitting the block.:cool:
my dist cap has a one marked on it.
Sweet! I got her. thanks
