Inner Axle Seals
Inner Axle Seals
Peanut Butter
Full Time Jeeper
Boerne, Texas
Replace them BOTH.
Don't do the cheap here either.
LG, by both you mean both seals - both sides? Bearings all look good. Even in the hub. If I had to guess, I would say they had been replaced before. Locking nuts had gouges in them from a screwdriver or chisel. Guess $10 for a socket was a little much. Rod
PS. LG or OldDog, any special tools needed to remove the differential bearings to get to the seals?
Thanks again, Rod
Since the shims are held in place by the bearings and I don't have a spreader, I just use a pry bar. Be careful though it's heavy and you do not want it to hit the floor.
I use a long 1/2" extension and a socket that fits to drive them out and back in. Also be sure to clean the seal surface good and use a little silicone to seal them.
I'd also check the spindle bearings and seals while it's apart.
Awesome guys, thanks. :notworthy: Inner axle seals are added to my shopping list. I will be installing them after Christmas. :chug: Rod
Mark and remove the bearing caps.
Lay some thick padding under the diff.
Put a rope around the carrier(after you pull the axles out)and just jerk the rope a couple of times. The carrier will come out.
May need a rubber mallet to re-seat the carrier when done.
YES- the seal on both sides should be replaced.
Sockets with extensions, is all you need to R&R those seals. Buy a spare seal or 2, in-case you "F" one up on install.
