Iron Duke carburetor
craveman85
Dolgeville ny
1981 cj8, gm 151, sr4, Dana 300, Dana 30, amc 20, 3.73s
Have any of you guys used carbs besides the Weber's on the GM 151 gm engines? I was thinking maybe the smaller sized autolite 2100s would work. Or is there something better I should use.
What's wrong with the stock carb? The Rochester is a great carb.
Had a Weber on it before I tore it down for a rebuild. Never could get it running 100% neither can my friend with his.
Won't be putting efi in it. I like to keep them period correct so it's staying carb.
fair enough just thought id give u an option however if u search for earlier iron dukes by pontiac u may have a better chance finding a carb that works better for that motor and will remain period correct
The other ones I found were all the Rochester computer controlled one. A 2100 could be found in junkyards back in 81 so I thought I'd try that route if possible.
The early to mid 80s Chevy s-10 had a non-computer Rochester.
if its a 2100 u want thats what i run in my AMC 258 i6 / 4.2l they r good carbs and easy to find and work on
