Steering Is a beefy steering box mount bracket NEEDED?
NotTJ
Maryland, USA
1978 CJ7 258 T150 D20 D30 AMC20 33" Yoko MT
My new to me 78 CJ has power steering and the box is leaky. I am gonna pull it and reseal and in the meantime was going to install one those beefy thick steel brackets because all the sellers of said brackets say my stock box could tear off the frame. Is this accurate? I have 33's on stock axles. I don't plan to do a ton of street driving - more trail fun. Nothing insane but I also don't want to ruin an outing because my steering box came off. Is the heavy duty steering box necessary for just 33s or spend that money elsewhere?
Solution
I guess for a small cost I should do it. Now I’m fearing backing out the vertical bolts that attach to the frame since I assume they go into a threaded nut in the frame! I assume that hasn’t moved possibly since 78 and rust may have taken over the threads 😱
clean the bolt holes re tap, So far, I haven't torn my steering box off with 33's and wild to quasi wild trial use.
You must use the right size spacer. Don’t mount like the red unit in the previous images. Your unit is okay.
Sorry my question wasn't about the spacer behind the shackle mount - that is critical and must be run. My question is about the holes in the crossmember. As you can see my bracket does not reach the holes in the crossmember. I've determined that it must be the bracket as sold to me - I will cut spacer to fit between the crossmember and the steering bracket but its a real shame I bought a junk china product for my Jeep. I should have returned this the second I saw the cosmoline.
Yea the MORE fits flush. You do also drill a new hole on top. No biggie. I try to only buy quality as much as possible. Once in a while you just can’t.
I'm ordering the MORE. This is rust busters thing is trash. Looking online I notice a couple people selling this exact part. Fishbone seems to be the same thing and when you look at their pics you can see one crossmember bolt goes in crooked (which is how this one would end up fitting) and you can see they built it to fit flush again the frame WITHOUT the shackle mount there.
Spacers would work...if they had included them...or maybe if they had cut it right in the first place that part would go up all the way to the crossmember. Junk
It’d be less than ideal to have a flush fit on that stamped steel crossmember. Ultimately, it’s your call.
Figure you are going in a different direction now, but for another project on the Jeep I found a wide variety of spacers I needed at the mom and pop hardware store near me
I have a shop and cut a spacer the size of the whole section that presses against crossmember. 3 little spacers wouldnt have much contact. And yes 3 bolts through crossmember like MORE.
That a boy!
On my last CJ7 I was running 33's 90% street driven. Decided to upgrade the steering bracket to improve tracking and wander. When I pulled the stock 2 piece bracket off, one piece had a crack running through it, not easily visible while fitted to the jeep. The new bracket bracket (in my case it was from Rugged Ridge) tightened up the steering a lot.
I'm glad I did that job before it completely failed me out on the road or on a trail somewhere.
Likewise on my shackle hangers. 2 of 4 were cracked when i changed out new better hardware for the old. I got lucky it didn’t break just going down the road.
$70.00
  35.0%
