Is This Normal?
hdgapeach
Old Time Jeeper
- Franklin, GA
- Right now, only one '76 CJ5. 304 with a three speed stick. Everything else is pretty much stock 'cept for a 4" suspension lift. Came to me with a back breakin' 4" suspension lift attached to a reverse shackle setup (Reversed the reverse shackle :dung: and now she rides like a Caddy!) Also posess a few 60s & 70s Mustangs and a couple of late 70's F150s 4X4s.
No, it’s absolutely NOT normal. Everything already mentioned is worth the trouble of checking out. If you’re lucky, it’ll be one or more of what everyone has suggested.
Personally, I have experienced the same ride characteristic with my CJ5 when I purchased it. It had a homemade shackle reversal modification that did nothing but make the ride harsh and the steering absolutely horrifying, because the modification altered the caster a ridiculous amount!
My CJ has a cheap 4” lift on it like yours, probably something along the lines of Rough Country brand. The “fix” for mine was to go back to the stock orientation for the shackles and hangers (kept the cheap lift). I tweaked the reverse set up until I nearly went loco and never got the Jeep to ride better than a buck board wagon. Going back to the original set up solved 100% of the ride quality and steering issues. I never intended to use the Jeep for the type of wheeling the reversal system was engineered to do, so it didn’t hurt my feelings one bit by going back to a stock engineered arrangement.
If all else fails in your attempt to get decent ride quality with what you have now, the original set up will get you the ride you’re looking for, even with the cheap lift springs. If you’re planning to do all the rock climbing and serious trail riding that the reverse shackle system is meant to perform in, you’re going to have to break out the protractor, level and rest of the tools it’ll take to minimize the issues you have now.
. I was surprised. It road great, so I left the lift as it was. Been that way for a few years now and other than checking the torque on the new bolts every now and then, it's been trouble free (so far).
