J20 Axles
Anything can be done. Spring perch width is much wider on the j axles so outboarding the springs is a must on the front 31.25 v.s. 27.5 i think. The rear would need new perches on the axle. If your plans are spring over your better off going G.M. Both fronts have cast in perches j20 under, gm over
