J20 axles
J20 axles
Out of my mind CJ5
ky
74 CJ5
scrap built CJ7
Alright i just picked up a set of axles from a j20 that measure 66'' backing plate to backing plate for $250. the rear is a dana 60 frint Dana 44 and its 8 lug. anybody used these before for full width conversion? was this a good buy? they have 3.73 gears and a locker, they will be going on a CJ7 with SOA and 4'' springs and 1'' drop shackles so i needed more width
thanks that helps, i have 37's for it. How hard would it be to weld on an outboard, i can weld sheet metal decent but have never done anything that important
Alright i just picked up a set of axles from a j20 that measure 66'' backing plate to backing plate for $250. the rear is a dana 60 frint dana 44 and its 8 lug. anybody used these before for full width conversion? was this a good buy? they have 3.73 gears and a locker, they will be going on a cj7 with SOA and 4'' springs and 1'' drop shackles so i needed more width
You can start here
Dana/Spicer Bill Of Material Numbers
This will help you ID just what you have. Dana 44 `s and 60`s came in many flavors. The BOM will tell you plenty
Dana Holding Corporation - The Expert Axle Bill of Material
The Expert - Information for driveshafts, u-joints, brakes, axles, heavy axles, light axles
The Dana 44 front axle bible
Mr.N's Dana Articles to Include 44, 60 informaiton.
Mr.N's Dana Articles to Include 44, 60 information.
This might help
Pics of outboarding springs
Google "out boarding CJ springs" and you will get LOT`s of information.
For parts. Highly recommend Dan at RuffStuff. His parts and customer service is simply great.
Frame Outriggers 4.5" [0692200] - $57.00
wow youre good ive been searching CJ7 outboard springs for almost two days and got nothing, thanks for all the links man i appreciate it
I could be wrong but wasn't the j20 set up for sua?
You might have been better off using a chevy front 44
as it was set up for soa.
