Jeep t-18 length question.
- Media
- 1
- california
- 1965 CJ-5 Buick V6 Ford T-18 4-Speed Spicer 20/18,Warn Overdrive Dana 30 & 44 w/Powr-Lok posi / both,4.27 gears 33" tires.
Hi IO,
The input shaft and low ratio countershaft assembly out of a donor T-18 can be swapped into the T-18 to make a low ratio or 6.32 1st gear Transmission . The ford input shaft is shorter with a different diameter spline and nose diameter. You can get a different pilot bushing for the crank to allow the ford input shaft to work.
I think the difficulty you are having is that you are trying to replace the input shaft on a Jeep specific T-18 with the 4:1 ratio. The Ford input shaft only works with the low ratio countershaft. The input gear must mesh with the drive gear on the countershaft.
You can probably find a ford T-18 in a Transmission boneyard to get the parts. If you want to keep the original Jeep input and the 4:1 ratio, I have a set of these parts leftover. The 6.32:1 ratio is the way to go if you can get the parts.
There are several sites on the web about this T-18 work. You may want to contact PartsMike.com for info and some parts. He is a good resource. Also Novak conversions has a good website for info and parts.
Good Luck- John in Alaska
IO,
The 6-1/2" length Ford input shaft for the 6:32 has 17 teeth and 1-1/8" x10 spline (so if you make the swap you need to use a Ford Disc.)........the correct counter shaft that goes with the 17 tooth input is a 43-36-27-16 There was also some difference's in input shaft Bearing size that I remember running into between the Jeep & Ford versions Although I believe Novak makes a bastard input shaft that somehow fixes that.
Also I'm thinking maybe the First/Reverse sliding gear may also have to be changed to a 40 tooth if it does not already have one in there.
I remember years ago playing with a Jeep T-18 could have even been a T-98 and were successful in making a 6:32 Low gear version out of a 4.02 but we had tons of parts scattered on the bench and several donors Transmission gear sets to work with. Sorry memory on this stuff is cloudy!
Novak in Utah would be a good one to call.............see if you can talk to there Gear Guy in the back..........I think his name is Brian..........works with this stuff daily. Smart Guy.
