Junkyard Tuned Port Injection For AMC 360
ThisGuyUKnow
Full Time Jeeper
- Featured
- 2
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Good thread. You have a long road ahead of you though. Few things...
I'm surprised you didn't rework a PROM just for initial firing given how far the timing table is off. 10 CIs is negligible, and displacement is just one tiny variable in a system of many. The biggest problem I see for you is that the spark tables will be way off for your AMC cast iron heads vs. the performance (at the time) aluminum heads on Corvettes of early 90's vintage. If the injectors aren't stock for a 350 Chevy or close, your fuel tables will be off as well.
The vette timing table is probably not quite aggressive enough at high loads (the aluminum heads need way less total timing) but WAYYY too aggressive at medium/low loads, i.e. where you drive the most. Lots of newbs to tuning think they can swap in vette tables only to discover they get almost constant knock counts and retard under any sort of engine load. So the current table needs to go.
Try to find a spark table from a bin from an application with non-swirl port, non-fast burn, cast iron heads as a starting point. like the 84 vette maybe. IIRC they started going aluminum in 86 (there was no 85) and thats when the tables started changing a lot vs. the stuff from the early 80s. Even the 84 table will probably need to be dialed down a bit but it should be much much closer than what you have now.
Now this timing issue is being exacerbated because you are currently at 10BTC as you describe it. I assume static w/ the proper lead disconnected, and not while the motor is running under ECM timing control at idle, right? The bin is probably "expecting" 0-6BTC, so all your timing is up to 6 degrees more advanced now, and the timing was already way over the top for your heads. The ECM can't measure timing, except relative to where it thinks you have the distributor bolted down. It expects the static timing configured in the BIN matches that of the distributor and makes all its timing decisions based on that assumption. You need to fix this first. If you need any tuning advice shoot me a PM. I'm pretty sure I have some iron smog head bin files around you can use as a starting point.
I think I have a little more insight one what was going on with the Timing. I got almost everything in its permanent situations today and was able to run the engine long enough to put a timing light on the engine. I initially set it the crank to 10 BTDC when I got the light on it, it was sparking after TDC. I rotated the diz until it was just before the 5 BTDC. Im not sure why the timing was so retarded when I lined it up with the dizz pickup but My theory is that it has something to do with the lock out of the vac and mechanical advance on the dist. I followed the bustedjeep TBI thread on how to lock out the diz and I am thinking that maybe that has something to do with it.
It is all set by the timing light now so should be good to go. Next step is to get an exhaust installed with the o2 sensor bung so I can get some good readings.
