Just curious to know.. What's everyone's crawl ratios?
jakeh937
- Petaluma, CA
- '79 Cj5, 258 with Howell Fuel injection kit, T18 with dana 20 Tcase, dana 30 front with Detroit locker, AMC 20 rear with LSD and one piece shafts, Warn 8k winch, 1" body lift, 2" suspension lift, 33 tires
I do not know what your plans with your Jeep are but I want to be able to do as much as possible with mine and I selected my 5 speed trans gears and tires based on wanting to drive on the highway and still be fairly capable off road.
The lower you go on your gear set the harder you push your motor on the road. That is why I suggested the Tera Low set for your transfercase. That will probably be cheaper to do than swapping ring and pinions![]()
Gotcha. I have thought about the Tera-low kit as well. I was playing around with numbers and if I go to 4.10 gears, with the Transmission I have I'll have a 55:1 in 4 low, granny low and running 60 down the highway turning about 2500 rpm. So I think it's going to come down to pricing! [emoji41][emoji41]
