Leaking driveshaft?
Leaking driveshaft?
76cj7chick
Old Time Jeeper
WA
1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Hi jeeper people,
I was under my CJ7 and noticed what appears to be a leaking driveshaft rod. Could I get some feed back from the experts?
I researched leaking/broken driveshaft but haven't had much luck on the Internet. I do plan on seeing if the u joints have any play in them though.
Hope to hear from you soon :notworthy:
Thats just some grease; totally normal.
Are those metal shavings or something on there or paint dust?
Grease will seep out of the slip yoke as the suspension cycles. That is normal
There is a seal in there that can prevent most of the grease from coming out. BTW, that pinion angle looks like it is a little low.
THANK YOU everyone for your replies! You've put my mind at ease!-- At least for now...:D:rock:
What is the "pinion" and is it bad if it's too low?? Do I need new u-joints, or?:eek:
It appears that your Transmission tailshaft angle , driveshaft angle , and rear axle pinion gear angle relationship is not correct, which should give you a vibration while traveling on the highway. Here is an explaination of what I am talking about:Tom Wood's Custom Drive Shafts - Driveline 101
It is pretty boring and hard to read but the pictures show what your driveline should look like with or without what is called a "CV" joint. I am just assuming that you are getting a vibration from your vehicle from adding high lift springs and not correctly coordinating the driveline together.
It appears that your transmission tailshaft angle , driveshaft angle , and rear axle pinion gear angle relationship is not correct, which should give you a vibration while traveling on the highway. Here is an explaination of what I am talking about:Tom Wood's Custom Drive Shafts - Driveline 101
Hmm... I haven't driven much since I've been "rebuilding" it. (my first- and probably my last) As for the "high lift springs", one of the previous owners added that. (Let me add that both the Transmission (GM Turbo 400 ) and the Dana 20 "spicer" were out of a Full sized Jeep Truck (the last owner knew nothing about the transmission. He didn't know it was a turbo 400 either-- at least that is what he told me. So, perhaps the angle is caused from the fsj transmission and Transfer Case , or not?:confused:
JEEP...Just Empty Every Pocket... :bang:
