Low oil psi and some start-up issues
IOPort51
- Featured
- 5
- Media
- 458
- Garland Texas
- 1977 cj-5
2006 Toyota Tacoma
very informative, thank you.
you are saying that the oil will thicken with temp rise and the oil pressure will not drop because of higher oil temp??
IO,
Well I don't think we have enough time here to teach a class in Thermodynamics but here are a few facts to think about.
When oil heats up it's viscosity will decrease. Engine oil does two main things, lubricates and transfers heat away from the lubricated part. Having to much oil pressure is just as bad as not having enough....reason is that you need the oil to move through at a speed that allows the heat to be taken away and still do its lubricating job.
Oil is designed via various base stocks to reduce friction at a normal specific operating temperature range's. Normally oil likes to operate about 50+ degrees above water temperature. Take it out of its designed range and it breaks down and can no longer perform notwithstanding that the block and associated parts become heat sinked which allows greater clearances that the oil can no longer protect. Add various additives and the oil can work in almost any temperature environment.
Not to bore you but the design of oil is quite complicated in the since that in the multi grades its designed to first while the motor is cold run like water to lubricate all the parts before damage occurs. This is also part of the bypass oil filter system so that oil gets in the motor quickly.Then the oil thickens up as temperature increases to again provide that envelope of protection. Take it out of its happy place and there is limited protection and damage occurs.
Hope that helps a little.
I race drag cars and I am forever chasing lubricating problems, we actually try to dry the motor up internally for two reasons, one is parasitic drag created by the weight of the oil and the other is combustion contamination caused by the oil during the firing cycle. We run Dry sump systems along with crankcase evacuators that suck negative pressure in the crankcase. Because of the lack of oil in the crankcase we use a lot of high tech coatings on piston skirts and wrist pins to make thinks live longer.
