model 20 inner axle seals
canuckcj5
british columbia,canada
76 body,81 frame, bored & stroked 366ci, d44/M20, chromoly everything, 35`s d300 twin sticked with 4.1,np435 trans,locked front and rear on 35`s
hey guys, just wondering, on the model 20, the inner axle seal, does it need to be pressed in from the inside out?
They press in from the outside in.
Yep. Pry it out with a seal puller, being careful not to mar the axle tube. Then install the new one with a seal driver or large socket till seated. Spring side in, rubber side out.
Measure the dept the seal is inside the tube before you pull it out.
I seat with a piece of PVC pipe that is just a bit smaller OD than the seal has.
the one that was in there is too big to be pressed in from the outside in, and the new ones I got were the same size, does anyone have a part number for this seal? im unbelievably frustrated right now cause I just spent over 1000 bucks on rebuilding this diff and this stupid seal went..
theres a bump inside, in front of where that seal sat
thanks
Pictures would be good-if possible.
It does and THX.
Take the old seal with you to show the parts guy.
Turns out there's a retainer in there when u upgrade to 1 Peice chromolys, which the pervious owner had done, also why I didn't know about it, pulled it out with a slide hammer & it uses the stock 13839 cr seal, I asked my buddy who did the swap and he told me, soo all done :)
You can put 2 inner seals in if needed.
Was the second retainer where the rub-ring was?
