You aren't showing me anything I don't already know. I can barely see my timing mark thru a tiny hole between the heater hose and AC bracket. No matter what you are going to need to see the timing marks to properly time your engine. If it is running you are close enough to time with your timing light. To make it easier highlight your timing mark on the balancer with, paint or a crayon. Also, it would be nice if you could get a remote timing light or one with the light on an extended arm to get the light close to the timing marks.
Honestly, your timing is close enough, don't worry about exactly where your rotor is pointing. It could easily be off on purpose. For instance, my DUI distributor can't be timed with the rotor pointing at the #1 cylinder due to interference with the power steering pump. So I moved the dist. over 1 timing gear tooth to rotate the dist. 1 gear clockwise. From your posts it seems like you get all hung up with the minutia and loose sight of the realities of mechanical devices.
By the way, if that is your engine compartment ..... nice, very nice indeed. Yours is exactly the reason I don't like the MSD system. Lots of parts and wires everywhere cluttering up an otherwise neat engine compartment. I'm yet to be convinced the MSD system is better than the DUI or HEI system.
