MSD Blaster Coil
MSD Blaster Coil
Dirt Works
Southern New Jersey
1985 CJ 7 6cyl, , 5spd, Dana 300, stock 3:31 rears
Upgraded distributor cap, wires and plugs a while back and want to replace coil with MSD. My ICM is the stock fender mount one.
Does anyone know which MSD Blaster part# is correct for this application.
I see there is one desiganated with a F for ford ignition system.
Thanks for the anticipated answers!!
Always better to ask stupid questions than make a stupid mistake;)
My guess would be use it if you want, I just run the standard Ford type coil. From doing some research on the net, for the AMC 258 i6 / 4.2l , which does not see excessive rpms, a conventional cannister coil would give the same results.
You should be able to use the 8202 or 8205. I have the 8202 mounted as a back-up to my stock coil.
I run the 8222 also.
$45.00
  22.5%
