Build Thread My 1971 CJ5 Build Thread
hazzo1
Just a small update...
My dad and I pulled the Transmission and the Transfer Case out Saturday afternoon to fix a leak we had between the Transmission and the bell housing. We found the oil was weeping out of a pressed in plug on the front on the case. We used some silicone and a homemade gasket to try to correct it....We'll find out if it worked after we top off the Transmission with oil...
We discovered a water leak while we were getting the cooling system ready...There is a steady stream of water leaking from the driver's side water pump port behind the timing cover....Looks to have the wrong gasket installed....Woo...
I started to refinish the set of aluminum wheels we have, but I can't see myself restoring these wheels by hand...So I have a buffer pad set coming from Eastwood. Should make things much less tedious.
But good news is that we are getting very close to firing the engine. I can't wait to finally hear this thing run!
My dad picked up a tire from TireRack while he was off on business. We'll use this one to mockup the spare tire carrier and to check clearances in the fenderwells. The exhaust might even get in the way. Haha
