Build Thread My 1971 CJ5 Build Thread
That sure doesnt look like your typical Ohio Jeep anymore. :) Very nice.
Nice headlights and buckets. Where did you find them? Brand?
Whole darn thing is nice!
hazzo1, you and your dad really know how to build jeeps.
Excellent job!:notworthy:
As I've said before "beautiful Jeep". The bumpers, you made or aftermarket??
Thank you! My dad and I built the bumpers. ;)
We didn't get the headlight bulbs installed until after I took all of these pictures....But the assemblies and buckets are original. Just cleaned up and a fresh coat of paint and clear.
Thank you!
when I get my 78 CJ5 I going to work on it build it I can guarantee it would not be this nice awesome job:chug::chug::chug:
It's been a while guy. Your killing me with the suspense!!
Sorry about that. haha
My dad has been traveling a lot recently and I have more fun when I'm working on the Jeep with him...ha
But here is a small update...
My dad and I pulled the Transmission and the Transfer Case out Saturday afternoon to fix a leak we had between the transmission and the bell housing. We found the oil was weeping out of a pressed in plug on the front on the case. We used some silicone and a homemade gasket to try to correct it....We'll find out if it worked after we top off the transmission with oil...
We discovered a water leak while we were getting the cooling system ready...There is a steady stream of water leaking from the driver's side water pump port behind the timing cover....Looks to have the wrong gasket installed....Woo...
I started to refinish the set of aluminum wheels we have, but I can't see myself restoring these wheels by hand...So I have a buffer pad set coming from Eastwood. Should make things much less tedious.
But good news is that we are getting very close to firing the engine. I can't wait to finally hear this thing run!
$150.00
  75.0%
