Need help identifying some vaccum line parts, 258
queuemay
- Atlanta, Ga
- 1974 CJ5, AMC 258 I6. Stock everything as far as I can tell.
My engine ('74 AMC 258 i6 / 4.2l ) has been bogging down when trying to drive off from idle. This mainly happens if I try to drive without letting it warm up for a few minutes. I cleaned the carb (lazily, just sprayed some cleaner down in there with the air filter removed) just in case I had a little build up, but I'm guessing its a vacuum leak. Couldn't find any leaks near the carb gaskets or hoses. But I did find that there was no hose connected to the thing labeled 3.051-6 between it and the carbeurator as labeled in the diagram in this link:
http://www.jedi.com/obiwan/jeep/wagoneer/pics/vac_advance_i6.png
Trying to figure out a) what 3.051-9 is b) where on my carter carb that hose should go?
I put my finger on the nozzle on there and it has suction, so should I plug it or put a line there?
I've got more parts to figure out but I'll start with just this one for now, thanks!
