Need help with removal of this part please!?!?!
Jackson, MI
That would be the torque converter. Look under/between the thin metal plate in front of it. There will be an access panel there. There are 4 nuts holding it on. Be careful, its full of Transmission fluid!
x2 on post #2
BTW look on the head underneath the valve cover the head will have the year cast into it between the valves somewhere near the middle of the head. it will be two digits so i.e. 86 would be 1986 have fun.
If you take the nuts off before you remove the engine next time, it will come off easier. You can use the starter to 'bump' the flywheel around if thats the very first thing you work on removing.
thanks to everyone for the great advice and help im just glad that im not putting that back on since my jeep is a stick, this is the first automatic ive encountered
