Need Packard Connector with Wire for front turn signal
HokieCJ7
Virginia
83 CJ7
Hi,
I recently purchased new front turn signals and running lights, but found that the old Packard connector on my 83 CJ7 was pretty brittle and didn't make the best connection. One of the wires connects partialy, so I usually dont have a turn signal. I have searched everywhere, but can only find all of the parts and tools to make a new Packard connector. No where can I find a pre-made connector with an attached wire. As the original and replacement turn signal light has this fitting, I would like to maintain the stock apperance and setup and replace the Packard connector coming off of the wiring harness. Does anyone know who might sell this, or has already purchased the kit and is willing to make me a wire and connector? Unless I am the only one, I could see a pretty good size market for this for somebody willing to make these for us Jeep guys.
Thanks!
Hi,
Thanks!
Ive got a big box of connectors at the house, the packard tool and connectors. If you can give a few pics of the connector you need and maybe a drawing of exactly what you need I can probably make you some thing up. Im gonna put a order in to get a few more connectors soon and if I dont have what you need I can order them.
Packard 56 connectors are available from: PACKARD 56 SERIES MALE 18 GA # 2965481 LOOSE TERMINAL - 30030
They have them all. $100 of parts, fuse block and some wire. The kits really don't save much time. You still have to run all the wires and terminals. :D
An ez wire 12 circuit harness is less then $200 shipped.. Even making your own you will be close to if not exceeding the cost of that.
I just had a buddy send me pics of his plugs and I'm pretty sure I have the connectors. I also have a box of Packard 56 male connectors that I can use to make the ends.. Ill send you a pm of what I need from you to make the plugs.
Just got home from work.. These little gems will go out tomorrow.
I could use 2 of those if you can get them for me too!!
I also commented on your headlight wiring post !!
Get with me.
Thx
1 week, 5 days, 4 hours, 30 minutes, 16 seconds
