Need reviews on CJ aftermarket windshield frames please
jonboy1919
- Media
- 49
- Maltby, WA
- 1979 CJ7 Renegade, 304cid, MC 2150 Carb, TH400 tranny, Dana 300 twin stick, Dana 44 front w/lock right, Dana 44 rear w/truetrack locker, 33x12.5 Goodrich's, Warn 8k, onboard air, Motorcraft TFI ignition upgrade, WipeBoy wiper upgrade, Painless wiring harness, backup lamps, Driving lamps, YJ brake booster and MC upgrade swap, Rear tow hitch
I have to replace my windshield frame due to semi-hidden stage 4 cancer. I need some confirmations/recommendations on the below quote. Have any of you fellow enthusiasts encountered a problem with wipers binding after buying an aftermarket windshield frame?
"One thing I'd like to ask you, though, is if you have a replacement windshield frame. Sometimes the hole locations on replacement windshield frames or aftermarket frames, are not accurately located, causing the wiper linkage to bind. Sometimes these frames have extra material on internal weld flanges, which can cause interference, thus binding." - Mark Lott, Rip Tech Engineering
I sense this is a problem on many Jeeps, although my wipers worked fine. Are there manufacturers whose frame is more accurately built and drilled, say Kentrol or Collins Bros?
Also, while I'm doing this, I thought about upgrading my wipers. Any reviews on the "WIPEBOY" product for CJ7s? Any and all info is appreciated. Thanks.
. I did some welding and bondo work on it to make it look better. One thing I noticed was it was painted on the inside. Looks like it was dipped. Also Ebay.
