Engine New Winter Project. Rebuild or Buy Remanufactured 258 i6?
Genaz
Silver Supporter
Easley, SC
1979 CJ7. 258cu 6cyl. T5 tranny/Dana 300 transfer case (both from '82 Scramber)
This winter's project will be the engine: 258c/6 cylinder. Not sure if I should have this motor rebuilt or buy a re-man. Getting different opinions. Never know what you're getting with a remanufactured engine, but the other side says by the time you do the heads, crank, cam, etc your better off just getting a re-man motor. Will be changing the intake and carb when I do this. Probably M/C 2100. Opinons and recommendations appreciated!
Like I have posted before……
Gotta LOVE AMC back then !!
Sometimes you have to Know Which Day of the Week it was Assembled!!
Line Changes were a regular Start of Shift Crew Meetings….
Good Luck on your Scavenger Hunt for one.
Just another Lead. Take the Measurements to a GOOD Parts House.
Ask for a “Cage Needle Bearing”. You will be surprised at what’s available.
If you find a Needle Bearing, Grease it WELL with High Temperature Grease for a Lifetime trouble free use.
I have done this on Hot Rod/Racing Builds.
Thanks for all the great input, guys. I found a brass pilot bearing on Advance Adaptors, that is 1.050" x .590". I'll be sure to remeasure several times before I get it off the engine stand and install.
They went into my 85 timing chain cover at the bottom……79 I don’t know.
Hi Everyone. Almost ready to drop the AMC 258 i6 / 4.2l back into the 79 CJ. I want to grab a new radiator and would really like an electric, dual fan set up. But I'm not sure of the installation to a fuse box, etc that old. Any counsel? Should I just stay with a good 3 core aluminum radiator?
Part of the kit
