Nutter Question/Clarification
CDT540
Austin TX
1983 CJ7
258, 5 spd
After the Nutter bypass is done, which removes the computer from the ignition system, you can remove all that maze of wiring and vacumn lines from your vehicle. I think the best way to do that would be to follow the instruction sheet that is used for the Howell Fuel Injection Kit:http://www.howellefi.com/pdfs/jeep_kit.pdf
On page 6, under "Installation of Electronic Components and Wiring Harness", it will instruct you on how to properly remove the oem computer and its wiring from the system.
That black wire from the ignition control module is the ground wire for it. The best place to run that would be to the battery ground, since the distributor does not need it(A lot of guys find that hard to believe), that could help the icm last longer since it would now have a secure ground. The green wire from the icm does go the the negative side of the coil also. The choke is controlled by the manifold heater relay and is not part of the computer that I can see reading the CJ wiring schematics. I would suggest that you ditch the oem carb for a motorcraft, since it is probably shot by now and this way you will not have any problems with the now disconnected computer fuel mixture control in it. Also you could check your distributor maximum advance for at least 28 degrees, from what I understand the oem distributor does not have full advance since the computer controlled that. Or, you could by a new remanufactured distributor, and they do have a full timing advance in them, since they are also made for the non-computer CJs. They are available from Four Wheel Drive Hardware.
If I have an aftermarket Tach and I am taking the lead for it from the Tach directly to the coil not utilizing any original wiring do I still need the green from the ICM to the coil. I guess what I mean is does the ICM green serve a purpose other than providing a feed to the tach?
If you disconnect the green wire from the icm to the coil neg., it will not allow the coil to ground and switch the coil on and off to fire the spark plugs. You can run the tach hookup to that connection with the green wire from the icm.
I would suggest finding a wiring schematic for your vehicle, they are availible online somewhere, the only one I have is for an '86 which is a bit different from yours, it is located in "My Gallery" on this site. I would suggest a shop manual to help you out with some of you other issues, Chilton has a Jeep manual with a section on emissions and so does the Clymer Shop manual. In the Clymer manual there was a page that had an application for a wiring schematic for whatever CJ needed.
    Best for votes
    on specific items
