Wiring Orangey Electrical
jeff_b
Missouri
70 CJ5 350/350
'75-'78 CJs used a fuse block with glass fuses. After '78, you got ATO fuses. Pre-'75, those early CJs didn't have fuse blocks in them. They used a few in-line fuses in certain places and a breaker on the headlight switch. So someone "hacked" in a fuse block from somewhere. You can get a generic harness with fuse block from Painless or EZ and wire it up. I do agree you should do something to improve what you have. Those blue crimp splices and various terminal ends are a recipe for issues and intermittent "gremlins" to trouble you. And what a pain for any future troubleshooting when you need to trace out a circuit.
Your suggestion to rewire is duly noted. It's a hodge-podge under the hood too, and at some point, some PO added hood marker lights. I don't intend to add a bunch of high-current stuff, but would like to add capability for interior lighting, maybe USB ports and I'll definitely liven up that dashboard lighter.
With my rig, I have EFI now with an ECM, push button start, and numerous other electrical add-ons and changes. I actually pulled the stock harnesses (under hood, under dash, rear) to lay them on the dining room table and with a crimper and soldering iron made my own customized harnesses rather than buy from somewhere. Now I know every wire, color, and union front to back. And it was cheaper than new kits from EZ or Painless.
Very interesting! Which fuse panel did you go with? Did you happen to make a wire run list I could pilfer?
Mine is an '84, so I already had a fuse block with the ATO style fuses in it. I simply kept that, but removed and cleaned and soldered the connections. I also purchased some of the plug-in connectors to add additional circuits. You can check here for more info: Fuse Block Connectors
In terms of a wire run list, or schematic, I used the stock CJ wiring diagram, and then simply added the additional circuits I needed (dual battery, OBA, LED spots, power outlets, audio power amp, extra speakers, inverter, 7-pin trailer plug, map lights, towing mode, power for lockup torque converter, neutral safety switch on shifter, ECM, keyless ignition, heated seats, digital gauges, electronic speedo, etc).
eBay has some listings for NOS fuse blocks/harnesses for around $100: CJ Fuse Block Another CJ Fuse Block
To use an actual CJ fuse block, you would need the square hole in your firewall where the fuse block mounts under the dash and has the bulkhead connector that connects in the engine bay side. Not too hard to do, but you'd have to cut a hole to do it. Your other option as mentioned earlier is a generic wiring harness. You could get one on Amazon for $40-$50: Generic 12-circuit harness, or a bit fancier but still under $100: Another Amazon Harness
If it were me with an older CJ that had the style with the glass fuses, I'd replace it with one that uses the ATO fuses (I did that on a prior '77 I had). If I were in your shoes with an older one that had no fuse block at all, I'd get a CJ block with the ATO fuses and wire it up like a stock newer model. Plenty of wiring diagrams and help that way. Sure, add additional stuff as needed (lights, etc), but newer stock to use existing parts, diagrams, and other people's examples. To me, that would be worth $100 or so to get one. Lots of people have used Painless or EZ and paid $300 or more for brand new. Great if you can/want to spend that money. But if not, get a used one and work it over to meet your needs. You've already got a GM engine swap (that's what I have), and I assume different alternator and ignition setup with that GM engine. But easy changes to a stock CJ harness. Be a lot easier adding or servicing in the future with a CJ setup, even if it's from a newer model. Just my .02 - well .05 now since no more pennies and we're all rounding now.
I'm glad I asked your advice! This rig has a very ugly hole chopped thru the firewall, and have a blank slate, but I like your idea of wiring Orangey like a newer CJ, your rationale is very sound.
Well, I decided to order a customizable Painless Performance harness, with fan and fuel pump relay kits, ground strap kit, and fancy split loom. Following excellent advice from TS8BC, (thanks again!) I intended to order the 22 circuit customizable for '75 (p/n 10106) and later CJs, but it wasn't available through Summit. I contacted Painless Tech Support, who said it's being redesigned and unavailable. They also said their p/n 20103 harness is identical to the 10106, but with GM wire colors! That made me laugh...... I came full circle from thinking about using a GM wiring scheme, ordering CJeep wiring, only to end up with GM wiring after all. Life is funny sometimes. I also ordered some adhesive heat shield for the hacked up firewall and tunnel to stick in there that might clean up the palette for the harness install. I should have all parts in three days or so...wish me luck!
I would say congratulations but you have some work in front of you. The good thing is when done your 40+ year old CJ will have modern wiring.
Thank you. Although it's my first CJ project, confidence is high. I'll take pics before, during, and after. Maybe I'll throw a build thread together if there's any interest.
Heat shields? Rugged Ridge rubber floor mats on a rhino lined floor isn't the best way to go?
