Overdrive, what would you do?
rocmoc
- 1970 CJ5, V6, 3spd, power steering, headers, electric fans, upgraded larger radiator, '78 grill, disc brakes (front only), swing pedals, hyd clutch, extended front shock mounts, upgraded front driveline w larger u-joints, warn OD, D30 front diff, lockers, 2100 carb, working on a '74 tub replacement, '78 windshield frame with '78+ Acme hardtop
Just added another CJ5 to the stable. I have a single Warn Overdrive , which one would you put it in?
First is '69 CJ5 with V6, T-14 , 4:88s, lockers, 33" tires, headers and used 85% off-road in USA.
Second is '70 CJ5 with V6, T14, 3:73s, open diffs, 29-30" tires and is used 80% on non-4X4 surfaces in USA & Baja.
Thanks,
rocmoc n AZ/Mexico
Thanks,
rocmoc n AZ/Mexico
