overheating and no coolant flow
elwood blues
Always Off-Roading Jeeper
- Media
- 71
- Solutions
- 1
- Export, PA
- 1978 CJ7 4.2L Comp Cam & valve train, MC2100 carb, MSD ignition, Dana 30 front, T18 trans, Dana 20 txfr, AMC 20 rear.
I just finished up a lot of work on my CJ. New, bigger lobes, COMP cam and valve springs, had the head pressure checked and magnafluxed, new timing chain and gears, new alternator, water pump, radiator & thermostat. I also installed a bigger Barry Grant 350 cfm street demon carb.
I got everything back together a couple of weeks ago, and finally finished up all of the little things I noticed a couple weeks ago. A small oil leak by where the oil pan meets the timing cover, an exhaust leak, etc.
So, I jump in and start down the road to the local 7 eleven. I only get about half way there when I can smell hot. Hot coolant to be specific. I stop and open the hood and notice that the top radiator hose has zero pressure in it, almost seems like there is zero flow. I also noticed that the temp gauge reads nothing. So, I took it very slow with very low RPMs back home, get in the garage, get the hood open (engine still idling) there still seams to be no pressure in the top hose. Also, there is no pressure on the system and I can open the radiator cap with no problem, the coolant doesn't seem to be flowing, but it sure is hot, steaming hot, not boiling though.
The temp gauge worked before I did all this. There are only a couple of things I can think of, wrong water pump that's spinning the wrong direction, but for a '78 I don't think that's possible, the difference is noticable between an '80 and new water pump compaired to a '79 and older AMC 258 i6 / 4.2l /AMC 232 i6 water pump.
The thermostat could be installed backwards, but I don't know if that would cause what I'm seeing.
Any advice you guys can offer before I start tearing things back apart is appreciated
