Padded rollbar
Padded rollbar
Rollie
Ames, IA
1975 CJ5, Basically stock except for electronic ignition.
I'm looking for a padded rollbar kit for a 75 CJ5 . I see them in the catalogs and on the internet for 76 and newer, but nothing for a 72 -75, Either that, or some other option that isn't foam wrapped around the rollbar and held there with duct tape. Thanks.
I am looking for the same thing and I have had no luck. If you find out anything please let me know.. :chug:
In all of the cataloges that I've gotten and all of the websites I've searched I've never found any for either a CJ5 or the early model (76-80) CJ7 's. I've mentioned this to someone else, but have never went through with it; you could buy a set for the '81 and newer CJ7s, and then take them to a local auto upholstery shop and have them tailor them to fit your rollbar. No idea what this would cost on top of the price of new rollbar pads too though.
I just have to wonder how much difference there is in the rollbars during that transition from the 72-75 models and the post 76 models? Just looking at pictures I don't see that much. But looks can be deceiving.
The newer ones are bigger the front goes down to the floor in front of the wheel well and the seat belt mounts to it.
I'm looking for a padded rollbar kit for a 75 CJ5. I see them in the catalogs and on the internet for 76 and newer, but nothing for a 72 -75, Either that, or some other option that isn't foam wrapped around the rollbar and held there with duct tape. Thanks.
:)You should only need it around the areas that the drivers or passengers head can come in contact with..............Amazon sells some zip up kits for 1978 and newer..........or Jegs or Summit for a high density foam designed for Race Cars. Keep in mind this product is designed to receive impact from a head with a helmet on............not a bare head.
Have used the standard soft black pipe insulation foam sold at Hvac supply stores........ not the Home Depot junk. Works real good either glued or taped on.
:D:D:D:D
Interior Dash Pad
Interior Dash Pad
