Power Booster Check Valve
Tin Medic
Ft. Carson
85 CJ-7 Renegade:
Fuel Injected 4.2L I6/T5/D300
D30 with ARB Air Locker, AMC 20 w/Posi
Warn 8000 LB winch
VIAIR Onboard Air System
33x12.5x15 Goodyear MT/R's
Kenwood head Unit
Hella E-Code Lights
Why cant I find the right size check valve for an 83 CJ power booster. The end that goes into the booster is around 3/4 while the only ones I can find are 1/2. No one seems to have the larger size, anyone have any ideas?
hate to suggest this but it may be time for a booster upgrade. I do not think the booster itself, let alone the check valve, is even manufactured anymore. :(
IO, I considered that but I am currently in denial about that option. :eek: Maybe someone has one laying around in a junk pile, if not then upgrade time.
Is your valve 3/4 with or without the grommet? Mine is 3/4 without.
Did you get another Jeep? I'm starting to think I missed something.
the hole in the face of the booster is 3/4".
3/4 hole . 1/2 on the check valve
Orielys had the right grommet don't remember the part number but it was in the dorman help section?
I was also there to get a fuel tank sending unit lock ring for a Chevy. Get this they only sell them in a variety pack 1 large gm 1 small gm and 1 ford?????
You know just in case.
Btw grommets also come in a variety pack.
I dont think I've ever seen one like that.
I've got he 1/2 inch one it was in it when I got it but the grommet was torn so I found a new grommet it works fine.
I know, that the first one like that I have seen. The hole in the booster is over an inch.
Ok, your friend is lucky to have you helping with his Jeep.
