Proportioning valve leaking again
bwmetcalf
Wimberley
'79 cj7, amc 360
Not sure if this is the right forum for brake questions, but my replacement proportioning valve now leaking quite badly. 1979 CJ7 with disc/drum brakes and it's draining, at least more quickly, the rear reservoir in the master cylinder.
I see a lot of posts related to ongoing issues with these proportioning valves. The one I purchased is https://www.morris4x4center.com/disc-drum-proportioning-valve-aluminum-mbm-pv2a.html.
My question is two-fold. Is there a better aftermarket valve that won't leak or at least has a better track record? Two, since it's a huge pain to get to the valve at the frame mounted location, can it be mounted near the master cylinder when I replace this next time assuming it's the valve and not just a fitting?
Thanks.
I would contact Morris and ask who they get it from.
Are you using DOT 3 spec brake fluid?
Do you have a NAPA in your area?
Take the bad p'valve in with you, so you can match fittings and port locations.
I have the CJ prop valve from inlinetube.com (VLM101 is the part number, IIRC). Installed early this year and no issues with it.
But I would try to figure out where/why yours is leaking. Do the threads/flares look good on the lines?
I looked at it more closely at it appears that it might just be one of the front brake outlet fittings. If I'm lucky, I can redo that fitting and fix it.
You might look into getting it rebuilt by a local brake shop. I got one that was remanufactured by Crown. It made a noticeable improvement on the braking.
Take a flare-nut wrench and see if all the fittings need to be tightened.
