Quadratrac
Quadratrac
Formula 40PC
Kirkwood
'76 CJ7, 360, TH400, Quadratrac
I have a 1976 QuadraTrac question if anyone has knowledge.
1. where was the vac hose route to? manifold? carb? and where at exactly? When I purchased the CJ it was not connected.
2. I have the mile marker kit that a PO installed, I know nothing about this kit and there are very few instructions online and even those are very vague. What all do I have to do to engage 4 wheel drive? Disengage? I know there is the turn dial in the glove box and hubs on the front axle but I dont know what to do & when and I definitely do not want to damage anything.
3. The turn dial in the glove box will not turn, I have pulled it out of the glove box while the vac hoses are still attached to get a strong grip and the dial wont move either way. Can I add a little lubrication to this without hurting anything? I would think that since it is just a pressure switch/dial that it should move fairly freely.
PB, I am only judging that I have the part-time kit by visuals. I have the part-time label in the glove box with the switch and I have hubs on the front. At first I saw the hubs and started to investigate and then I saw the part-time label and would think that someone wouldnt just add that for decoration.
I have low gear on the T/C and the handle on the floor tunnel but someone broke the linkage and it was laying in the back of the CJ when I bought it. I have a spare that I was going to install.
I too have the 1976 CJ7 with GM Turbo 400 & QuadraTrac , I like the idea of all this because my wife will using this as her daily driver soon and it seemed like a better system then manual tranny and regular 4wd. I kind of wish I did not have the MM kit so I could experience the full QuadraTrac experience.
I am just getting things going but intend to take the CJ in to have my Transmission guy look it over, I also just bought a GM Turbo 400 , QuadraTrac T/C and a front axles with disc brakes off a guy for $AMC 150 , he had a whole stockpile of trannys and axles and was selling everything cheap. I am going to have the Transmission & T/C gone over so I have a spare when needed.
I still have 2 questions that need answering, where does the vac pressure tube connect in the engine compartment? carb? manifold? which outlet?
Also, I cannot turn the dial in the glove box, can I add some lubricant to this without hurting anything?
Manifold vacuum. Lube may not fix it. The switch is only plastic. Might want to buy the switch BJ's has. Good idea on getting the extra parts. You can easily change back to AWD with a rebuild of the extra Transfer Case . They are heavy, but not hard to remove and install. You can rebuild one yourself by doing some reading and studying. My build thread has where I rebuilt mine. The links are really good information. If you do switch back to AWD, you will need to keep the front hubs always locked. The GM Turbo 400 is one of the easiest automatics to rebuild. I plan on rebuilding my extra myself. Just Make sure you use only parts from BJ's. Don't let some mechanic tell you anything different. Yes their stuff costs more money, but not in the long run.
Do you have a picture where your QT vac pressure hose hooks to the manifold?
I have attached pics of my QT switch from the glovebox It must be different then the one you have, this one is all metal. Works good, I thought it wasnt turning but it was the way I was holding it when it was installed so I took it out and it turns and works correctly.
Does anyone have knowledge of or pictures of what the front axles hubs looked like on a CJ7 with QuadraTrac ? I have a part-time kit that a PO installed but may think someday of switching it back, I really like the idea of the fulltime 4wd.
PeanutButter probably knows but www.grimmjeeper.com has it for sure.
It did not have a low range.
If it came with the optional low range it would be 2.57
If you go to this page you can figure everything out. Gear Ratio Calculator
You can select the GM GM Turbo 400 , the Borg Warner 1339 (or QuadraTrac ), you need to know the axle gearing, if you don't there are was to figure that out.
Once you have input all the data, you can compare what different axle gears will do, it will give you highway speeds at certain RPMs and what RPMs you should have at a particular speed. Very handy tool.
or you can multiply Transmission 2.48 BW 1339, 2.57, axle 3.54. assuming you have standard factory axle gear ratio.
Your crawl ratio is 45.1
or you can multiply trans 2.48 BW 1339, 2.57, axle 3.54. assuming you have standard factory axle gear ratio.
To expand on the above quote, your gear ratio would be 23.1, your crawl ratio as mentioned is 45.1
I didn't read the ratio calculating website posted in this thread, but most, if not all don't include realistic crawl ratios for autos because they don't use the torque multiplication factor of the torque converter.
The Transfer Case will increase the output torque by approximately two times, making the actual crawl ratio almost double.
Because the multiplication factor is a variable one, and it changes as the RPM moves up it's best to calculate your crawl ratio with an auto Transmission by multiplying the nominal result by 1.5 up to 2. I just doubled the first gear ratio in the 400 to get a 45.1 crawl.
You can get a more actuate crawl ratio by factoring in the torque at the flywheel, and tire size as well.
The t-case will increase the output torque by approximately two times, making the actual crawl ratio almost double.
Because the multiplication factor is a variable one, and it changes as the RPM moves up it's best to calculate your crawl ratio with an auto trans by multiplying the nominal result by 1.5 up to 2. I just doubled the first gear ratio in the 400 to get a 45.1 crawl.
Thanks for this information, It was something I never considered. With regards to the torque converter is the oem unit sufficient for everyday normal on and off-road use?
Posi can chime in but it's my understanding that absolutely is a good answer.
The whole driveline is rated for 3/4 ton use and it's in a 1/4 ton vehicle. As you well know, it's the exact same driveline found in the Wagoneers in Cherokee's and pick up trucks including the 3/4 ton ones.
Absolutely!
"Standard" axle gear ratio 1976-79 was 3.54 regardless what drivetrain you had.
Jeep Axle: AMC 20
