Question after Nutter Bypass Complete
nivensid
Marshville, NC
'86 CJ7, 4.2L, T5, D300
The relay is for your choke/manifold heater. You need to do a little splicing to get it back to operating. Looks like you need to fix the wire going to the coolant temp sender as well (looks like it was cut half way?)
The six pin connector can go away, but the red wire is part of the relay. Tells the manifold heater when to shut off. It runs to the relay.
https://goo.gl/photos/t6PQsnLEDjwwK5pU7
Thanks, I will get the relay wired back up. There for awhile it was like a birds nest of wires and i got carried away. I saw the coolant temp wire was frayed and need to fix that. I have a mechanical gauge but still don't need open wires. Good observation and thanks again.
    Best for votes
    on specific items
