Build Thread Question
Whitewullff
Sorry can’t find question tab and I’m too frustrated beyond right now. I have a 76 CJ7 AMC 304 that absolutely will not start. There isn’t any more reasons for it not to start. I’ve researched every possible thing and have replaced it all and aligned everything and it just cranks but will not fire over. New points, been gauged correctly, new coil, ballast, solenoid, distributor, new fuel lines flushed tank clean gas, new pump and filter . It’s getting compression fuel and pressure getting spark from the coil to the plug. Set timing by hand put mark at about 15* degrees btdc . Rotor is point towards number one plug just a litte before on compression stroke . Brand new plugs, cap is in correct firing order. Carberator is a motorcraft 2150 and i rebuilt it just incase. Cleaned blew out all jets. On and on it’s been done. I just want to push this money pit off a cliff beci certainly can’t sell it nobody would buy a $30k dollar POs that won’t start
