Re-Assembly Transmission to Transfer Case
If this is on the bench-it shouldn't be that hard.
If the tranny is in the jeep, T'case install can be a bit of a PITA because it's had to see that they are lined up.
make sure both are in gear and try turning the Transfer Case output while inserting it onto the Transmission . the gears may not be lining up.
Both are on the bench. It was not easy to separate and equally difficult to re-attach. I engage both into gear still no luck. I will keep working it, just checking to see if there is a trick to it. Thanks
