Diff Rear differential problem. Drive shaft spins but the axle won't
Differentials
Marsh Dweller
St Augustine, Fl
1982 CJ7, 4.2l, T5,
Has anyone had this problem? My knowledge of differential is about zero. Anyone have any advice? Thank you in advance
Solution
Your 82 CJ has an AMC 20 (Cooperate) rear axle (Link)-> Differentials -<
It is common for the hub to spin on the axle and then you end up going no where. If you mark the axle to hub (the right hub is the common drive hub) with a line it will show if it is spinning.
I'm betting it is...
To repair the problem, the most common fix is to purchase a 'One Piece Axle Kit'...
Your 82 CJ has an AMC20 (Cooperate) rear axle (Link)-> Differentials -<
You can purchase a replacement axle and hub, but it is not as strong.
Solution
My 0.02 - scrap that old AMC20 for something better. If you decide to keep it though, definitely the 1-piece upgrade like CJ said. It's easy to do.
I run the old AMC20 with one piece shafts and wheel quite well with it. If built right they are actually stronger than a Ford 9" due to the 11" ring gear. However they get a bad reputation due to the two piece axle shafts and thinner wall tubing.
Do what was mentioned above. However if that checks out pull the rear diff cover and look for broken of missing teeth.
Thanks for the advise y'all! I ve been wanting to do 1 piece axles anyway. How do i get the cap off to get to the castle nut? Is it pressed in?
It's plastic just pull
