Rear main seal....HELP!
- Solutions
- 1
- Springfield, Missouri-U.S.A. Earth
- '85 CJ-7, 258/4.2L 6cyl. Bought new in 1985. Full cage, Warn 8274 winch, Ford 9" rear, front/rear Detroit Lockers w/4:88 R&P. T-5 tranny and 4:1 t'case. 33X12.50-15 BFG/AT, MSD ign, on board air---
Chems in the 'high-mileage' oil will swell seals some.
The reason you see the oil where it is-Is because that's a low point, and it gets blown back there also.
You should try some 15W-40 Rotella.
Also-clean your PVC valve. Plugged/dirty PCV can cause the block to build positive PSI.
Is there a way to tell if the RMS is bad after the pan is pulled ?
