Rear pinion shims
Rear pinion shims
jakeh937
Petaluma, CA
'79 Cj5, 258 with Howell Fuel injection kit, T18 with dana 20 Tcase, dana 30 front with Detroit locker, AMC 20 rear with LSD and one piece shafts, Warn 8k winch, 1" body lift, 2" suspension lift, 33 tires
What's the most * shim you can use without it having issues or being unsafe. I talked to a guy at tom woods and he said they sell up to a 12* shim. Anyone running his high? Is this okay to do?
Use what is necessary to get the preload correct.
Castings can vary quite a bit but can’t change and never would have left the factory if it was out of spec.
You should be able to use the same shims or at least the same size that came out of it.
I am so sorry I wasn't more clear. I am talking about driveline angle and shimminge rear axle
If you are going to have to add that much shim, the best thing to do is cut the perches off and reweld them at the correct angle. If you can't weld and don't know someone who does, make sure that you go with steel shims, not aluminum.
Do not use 'cast' shims. Use steel only. ;)
Don't forget to buy new/longer centerbolt for each spring pack.
Use only the amount of shim needed, to get you into the high side of OEM specs.
