Rear shaft not spinning
CJ7 Jeeper
Old Bridge, NJ
1979 CJ7, 304 V8, TH400 trans, Quadratrac transfer case, Dana 30 front, AMC 20 rear.
2006 Streetbob
Hey everyone, I recently bought a '79 CJ7 with Quadra Trac. I was finally able to get it on the road and I noticed it riding really hard. At first I thought that's the way it rides, but it just seemed like it was moving in front wheel drive only. Well, I jacked it up in the front and back. When the front hubs are locked and I put it in drive, all 4 tires spin( front spin really fast and back only spin when I give it gas). When I unlock the hubs the front drive shaft spins but nothing happens in the rear. The rear drive shaft doesn't even move. I read a lot about QT and I guess I get it. I think as long as you unlock your hubs, it would be in 2WD? Anyone have an idea why my rear isn't turning? :mad:
Thx, Vinny
Thanks Lumpy Grits. I've seen that clip before. It's not that I don't get QT, it's more that my rear drive shaft isn't spinning. Also, I forgot to mention, my QT vacuum lines are not hooked up. Don't think that has any bearing on my rear drive shaft though...it should spin with my QT in regular or emergency mode, right?
I don't know alot about the Quadra-Trac but I don't think they came with Lockout Hubs. Sounds like someone has tried to change it to a normal 4WD instead of full time 4WD.
Me thinks your 'rite' about the hubs.
OP-Do you have the low-range lever in the glove box??
The tub was changed, no lever by driver seat or anything in glove box. I have the selector for QT though, just not hooked up. So I might have a different front axle? How is that affecting my rear?
I read that hubs were an option in those QT years.
Post pictures so we can see what you have.
Thx to all. I figured it out. I dropped my Transfer Case and opened the vacuum window. PO jammed the vacuum diaphragm tube in and the shifting fork was too much toward the rear to engage the gears. My gaskets and replacement vacuum parts are still on order, but problem is solved, thx again
