Rear wheel popping sound
jbaker4341
I'm getting a popping type sound coming from my rear drivers side wheel. Its seems worse when backing up and turning. At first, I thought it was the wheel bearing so I had those replaced at an auto shop. Still getting the same symptoms after the bearing replacement. I have 35" tires with lift, Dana 44 rear end with 4.56 gear ratio, Limited slip diff. I replaced the diff oil not to long ago and didn't notice any broken gears or metal pieces floating around. Any ideas what could be causing the noises?
