Rebuilding a 1983 CJ8 Scrambler
Eugene
TN
1972, CJ-5 Renegade (304 w/ 3 spd) all stock (restoring)
1983, CJ-8 Scrambler (258 w/ 4 spd) all stock (restoring)
2001, TJ Sport Wrangler, (I-6 w/ 5 spd)
2008, JK Unl Sport Wrangler, (v6 w/ auto)
2009, JK Unl Sport Wrangler, (2x2 v6 w/ auto)
Hello all...
I have two CJ rebuild/restore projects in the works... I know. Lost my mind, but the second is a CJ8 Scrambler. Same make and model as my first Jeep... ever; I couldn't resist.
My quick question is this; will a 3sp Auto (32rh) Transmission from a AMC 258 i6 / 4.2l I-6 (YJ) bolt up to the original CJ AMC 258 i6 / 4.2l I-6 in the Scrambler?
I appreciate all input, feedback and any lessons of wisdom you can offer me... yes, I'm a newb at the rebuilding.:notworthy:
Hello all...
My quick question is this; will a 3sp Auto (32rh) trans from a 4.2L I-6 (YJ) bolt up to the original CJ 258 I-6 in the Scrambler?
The AMC 258 i6 / 4.2l Yj is basically a AMC 258 i6 / 4.2l Cj. The Transmission will bolt right up. What Im not sure of is if the Dana 300 will. I thought the Yj actually used the TF999 ? Im not really up on Yjs though.
yeah as far as I know the TF999 was the yj auto behind the 6 cylinder but it should bolt to your engine..I think the 32 was used in 97-02 tj's behind the 4 cylinder as well as the 4.0
The YJ's (88 and up) use the NP231 Transfer Case , so while the later Transmission will bolt to the motor, I don't believe your Dana 300 will bolt to the Transmission without an adapter. Best to call someone like Novak about what you want to accomplish.
Ive just done a ton of reading on the NP231 and the ones that came behind the autos had a 21 spline input shaft. How does that mater to you you ask?? your Dana 300 has a 23 spine input. Thus the Dana 300 would not fit unless you either change the output on the Transmission or input on the Transfer Case .
Good luck.
Trans 81 CJ8
