Refresher course in carburetors
MrFurious
NW Ohio
1979 CJ5 AMC 304 T150 Dana 20 Wide-Trac Dana 30/Dana 44
i honestly cant tell you what goes where but as long as you have your vacuum advance, pcv valve, and brake booster (assuming you have power brakes) hooked up i'd plug the rest of em off. excpet the one on top of the float bowl which i'm guessing is a vent, maybe its supposed to have a return line to the fuel tank. i have a mc2100 so i don't know much about the 2150
Thanks Elwood!
The PO ditched the canister as well, so I guess I'll need to figure out where he hid the vapor return line for the fuel tank. Assuming it's nowhere to be found (i.e. terminated at the tank end), would it be reasonable to assume one could just run this up to the air cleaner assembly?
Other than that it sounds like I just need a cap and a T-fitting.
I'm not exactly positive, but I thought that the fuel system on the CJ's was such that it needed the vapor return line to the fuel tank to prevent vapor lock. I might be wrong though.
If the vapor return line was removed/plugged prior and it ran okay, I would say stick with it, but it may be something down the road you want to reinstall....
The two stage power valve, I'm not extremely familiar with them, I've read a lot about them and I know that they are harder to find and were only used for a few years on the larger Ford motors. I do know that if you don't want to screw with it, you can take the power valve and cover from your 2100 and install it on your 2150, it should work no problem. And if you need a new power valve, you can get Holley power valves from Summit, the Holley power valves are interchangable with the Motorcraft/Autolite carbs. The thing with power valves is to get a good vacuum reading from a good (not vacuum advance) vacuum port, something off the exhaust manifold would be best. Take that number (typically 16-19) divide by 2 and that number is the setting you should get for you power valve. I'm not sure what the formula is for a two stage power valve.
The bowl vent port is strictly for evaporative emissions control. The line is supposed to go directly to the charcoal canister to reduce how much is evaporated out of the venturis. There's a solenoid that's activated once the engine is running and up to temp to suck the fuel vapors out of the canister so they can be burned rather than just spewed out.
Legally speaking, it needs to be used if the vehicle came with it originally. If not, you can just cap the tube.
$45.00
  22.5%
