Replacement shifter
Replacement shifter
DRoss
Phoenix, AZ
1984 CJ7, 258 CI, T5
My 1984 CJ7 has the T-5 five speed. I understand Hurst no longer makes a replacement shifter. There's lots of slack in mine. Any suggestions for a replacement? How about the Mustang T-5 shifter. Will this fit and would it be long enough?
Thanks,
Dave
Thanks,
Dave
My first reaction is that the isolator and clip that holds the shift lever to your shifter is worn out.
Take the shift boot loose and pull up on the shift lever. Does it come off?
If so then you need
Original Replacement Parts J3241239 - Isolator Clip for Jeep® Vehicles with T4 or T5 Transmission or NP231 Transfer Case - Quadratec
Original Replacement Parts J3241481 - Shifter Isolator for Jeep® Vehicles with T4 or T5 Transmission or NP231 Transfer Case - Quadratec
If you really need a shifter then some of the other T-5 shifters will fit the top of your t-5 But the lever will be shorter and have to bolt on.
