Rescued Grandfathers Scrapyard 79 CJ Rebuild - Steering/Suspension/Drivetrain
Just the little farm tractor. Kubota L2501 with pallet forks. Great for anything under 1200lbs. After that we have the big brother.
That's great you have access to "Big Brother"! If needed...
Ok so, I’m sitting here with my father in law having some wobble pops, and I’m learning some more about the Jeep. Apparently it used to have Renegade decals on it. Now on top of that, my father in laws 78 CJ7 is in my yard right now as they are moving. The back seat in that jeep is the one out of my wife’s jeep. Things get cloudy with details, but everyone is 100% certain that this back seat is the one from the 79 CJ5 . Someone tell me I’m crazy, but is this a Levi (Edition) ’s seat? Could this have been a Levi (Edition) ’s? I swore it is a base model, maybe it’s something more? Any insight from anyone?
One thing I noticed is some of my posts, maybe slightly inebriated, about the seats and stripe decals aren’t showing. Hopefully I didn’t break a rule or anything.
If you look at the top of the forum you'll see a big red notice we had a big database crash. I thought I restored all the posts but I must of missed a couple. I'll find your missing ones on my backup site and restore them.
Ahhhh ok. No worries at all. I may have rambled a bit as I was indulging, was hoping I didn’t break a rule or something. If you can’t find them, it’s no big deal. It was mainly about the seats being Levi (Edition) -esc and that the Jeep is almost certainly a Renegade . Or at least used to have the renegade decals. Thank you so much for all your work here, you sir are awesome 🫡
Ahhhh ok. No worries at all. I may have rambled a bit as I was indulging, was hoping I didn’t break a rule or something. If you can’t find them, it’s no big deal. It was mainly about the seats being Levi-esc and that the Jeep is almost certainly a renegade. Or at least used to have the renegade decals. Thank you so much for all your work here, you sir are awesome 🫡
All posts restored... :)
Great, cheap is good! BTW that is one long four door white truck. It should be labeled as a SEMI.
Nice blue Ford. And Jeep. :chug:
Ok so since life got in the way, I haven’t touched the Jeep in a few months, but now back at it. Anyone have a coolant hose diagram? I got a cheap aluminum radiator and the upper and lower hoses, I also went ahead and paid for a battery wire kit, I only had 1/0 and 4ga on the shelf. In theory, I should be able to start it in the next couple weeks. After verifying all my wiring, that should be good. It currently doesn’t have a heater core, so this is my understanding. Upper and lower rad hose are self explanatory, the hot inlet to the heater core would be back on the intake manifold, the outlet from the heater core would go to the lower small port on the water pump, then the to small port on the water pump would go to the small port on the water neck. This is what I am tracking. Since there is no heater core, I would bypass going from intake manifold rear, to lower small port on the water pump. This make sense to me, but just want a sanity check. 5/8 hose for the small lines?
