Ring and pinion
Germy
Full Time Jeeper
- Cincinnati, Ohio
- 1985 jeep cj7 360 20 rear and 30 front w/warn lockers 5 speed tranny,
1971 dodge dart built 318
they also have 4.27 for Dana 30, not sure about 20 rear though...
What size tires are you running? I love the 4.27 for 33" tires. Really don't understand why its not a more popular ratio. It's a very well balanced freeway and off road ratio for me...
I could imagine! Thanks all! Off to empty the pockets again!
Was thinking 4.56. I want a little more get up and go, no highway, just cruising.
Are replacing the axles something that a pro needs to do?
not really, but you need to press the new bearings on.
) down the shaft on and put new races in the axle. That is how I'm set up,too. Running 33's, but I also have an Overdrive 5 speed tranny. Cruises good at highway speeds.Was thinking 4.56. I want a little more get up and go, no highway, just cruising.
Not the axle isn't hard the hard part is set-up on the ring and pinion close isn't good enough it has to be prefect or you ring and pinion will not last long. I would sujest a one piece axle in the 20, at least. I also up graded the 30 axle with 4340 chromoly axles there about $658 for the set when I upgraded. It cost me about $800 in labor to replace the axles and set-up both ring and pinions. All the parts I put in cost about $2000. Do you have lockers or open diffs. Not sure but I think in your set-up it said you have warn lockers im not sure but I think you might be talking about your locking hubs and not the differantcal lockers. Which would be another thing to consiter while you in there regearing and put axles in.Thanks for the info! I'm pretty sure that I am running 2.73. Are replacing the axles something that a pro needs to do?
