Roll Cage Padding
JeffP
- Media
- 28
- Peoria, AZ
- '75 CJ5, 304, T18, D20, D44s w/3.73 1974 CJ5, 304, 4 spd., Dana axles 3.73 gears. 1973 CJ5, 258 I6, T18, Dana 20, Dana axles 4.27 gears. 1972 CJ5, 304, 4 Spd, Dana 20, 4.27 gears. 1976 CJ5, 304, T150. 1976 CJ5, 304, T150, J20 w/4.10 gears. 69 CJ5 Hurricane 4 cyl, 4spd all original! ‘53/‘54 M38a1 100% original but also 100% apart! Low 3 digit Vin! One of the very first m38a1s!
This won’t be for everybody but back in the ‘70’s you couldn’t just go out & buy roll cage padding... at least not that I know of. So what we did was find a suitable padding, often pipe insulation and wrap it with 2” wide black vinyl tape. Like electrical tape, but 2” wide. What we used most often was “Christy’s” brand tape.
I’m a purist when it comes to restoring old Jeeps so what I’ve been using the past few years is “pool noodles” and the exact same tape we had back in the 70s.
Pool noodles can be had at the dollar store for $1 each! Can’t beat that. The thickness and densityis perfect and they are weatherproof.
The tape I found at Lowes! Exact same stuff from “back in the day”. Functional with the exact look I need. Most of the Jeeps I restore are 72-75 CJ5 Renegades.
Hope that helps.
Hope that helps.
