Roller valve - Part Question
JeepDave
Frederick, MD
'78 CJ7, 304
If you do not have a gas tank vent, a vacuum will form in the gas tank as the tank drains of fuel. This will eventually prevent fuel from getting to the pump. A vented gas cap will help here if it operates correctly.
I’m still at a loss at to why you have fuel traveling vertically up into your rollover valve in the first place, I wonder if you put a light weight spring on top of your float if that would help stop it from sticking, like a spring from a Holley carb vacuum advance
Sent from Texas using Tapatalk
The fuel pickups for the check valve and rollover valves are located on the left and right side in the inside top of the gas tank. So to get fuel in them would require gas sloshing around in a fuel tank with lots of fuel in it or a lot of off camber driving like off road. Still the valve should not stick open. So if you still have a sticking problem with it after inspection and cleaning, replacement would be a good choice. From what I understand they only came in the CJ.
Not sure...but you should have some sort of venting system by the fuel inlet / filler. I think you could just run a fuel line from one of those little outlets right to the other in a horseshoe, clamp them both and be fine if the standard vent setup is functioning.
Thanks, doesn't using a single tube from one outlet to the other create the same issue? It seems like creating a horse shoe creates a closed system not allowing air to escape. Do you have a picture of what you're referring to?
Thanks for the idea. I still have the part and plenty of hose. I'll take a look and see if that would work.
Yeah I too couldn't figure out why so much gas was being forced so far (and vertically) under so much pressure. I'm definitely not off roading yet so continually flooding the vent ports isn't an issue. I'm sitting on a stock suspension with 33s so I'm definitely not flying around curves :) I have to replace the fuel sending unit, maybe that's contributing...
I don't have to worry about emissions in MD and the PO took out the canister so I figured that I'd do away with the who thing completely. Just need to find a part that'll vent the gas tank. A vented gas cap is a good idea although I like the original-looking gas cap (slim, silver with black grip).
Well you’re not allowing fuel to escape. You’re venting isn’t done there it’s done on the other side as a part of the filler structure / gas cap.
