Roller valve - Part Question
JeepDave
My rollover valve was spewing gas so I decided to take it apart and have a look-see. Cleaned it, put it back together and reconnected all the hoses. Ran my rig for about 20 minutes only to realize gas was streaming out of the canister portion. Took it apart again and upon closer inspection, when the float goes up, it doesn't come back down in the cylinder, it goes up too high coming out of the cylinder getting cocked at an angle allowing fuel to pour in and continue forward toward the canister (if I had one).
After realizing it was a loss cause I decided to pull it out and simply clamp off the two hoses coming out of the gas tank, no more gas leak. However, I'm worried because the tank can't breath. Below are three hoses, two coming out of the gas tank and one that runs to the front of the Jeep (I put a screw in it for the hell of it, no canister in the engine compartment).
I'm looking for a part I can push into one of the hoses coming off the gas tank so as to allow the take to vent w/o introducing contaminants.
Would the piece above fit the bill? I was going to back out one of the screws from one of the hoses coming off the gas tank and plug it with the piece sticking out. Is it safe to assume that I can simply zip tie this somewhere up high to avoid contact with water? Thanks all!! JD
