Separating trans & transfer case
cdlongjr
Newark, De
1983 Jeep CJ-5, 1987 Wrangler YJ, 1974 J-10
Can I separate them under the 5 or do I have to pull both & separate on the ground?
I also want to replace the mount. What do you guys recommend?
Thanks CJ.
I have everything unhooked/unbolted. I have removed the bolts in the oblong plate to separate the tranny & Transfer Case . Should I have removed the 6 bolts that are in a circle instead of the bolts in the oblong plate? I haven't attempted to pry the two apart yet.
CD
302-690-9046
I believe the six bolts in the circle (that go through the adapter plate) go in from the front and have to be removed after you pull the case.
I circled the ones in the attached image I think you are talking about.
Ide pull the floor pan and remove the shifter.It usually gets in the way seperating it underneath as you bring the Tcase down.
Thanks CJ. I hav removed the wrong ones, but haven't separated them yet. Shifter is unhooked & bottom is moved forward. I think it will be out of the way.
It's out. Intermediate gears & gears that turn front driveshaft are shot. Tapping noise was when 2 of the gears that were missing teeth at the same spot meshed.
Here's hoping it goes back together just as easily as it came apart! :chug:
The novak parts are great. I'm rebuilding my Dana 20 and T-150 .
It's taking a long time as I'm cleaning them and painting the cases.
Good luck with your rebuild.
Trans 81 CJ8
