setting pinion angel
bzahler
Wisconsin
76 CJ7 304, turbo 400,Dana300,dana 44 front,dana 44 rear SS twin stick 4.5 Rubicon express lift,Warn8274,
I am in the process of putting a Dana 44 in my CJ7 .I plan on running a CV drive shaft and I know to point the pinion at the TC but do any of you think I should get the drive shaft first? Or do you think I can use my old on for mock up? any thoughts?
thanks :chug:
I used the oem driveshaft, and added a heavier tube. The shaft was shortened to accept the cv joint, and the pinion angle was rotated to match the driveshaft angle.
you can indeed use either for mock up I suppose its up to your level of patience on wether you can wait on the new shaft to show up before you burn in the spring perches :chug:
Thanks for the help I think I got it !:chug:
