Trans SM465 to a Iron Duke 4 cyl
Super8mm
Silver Supporter
Bronze Supporter
Grapevine, TX
1980 CJ5, 4 cyl, Borg Warner/Ford SR-4 4 spd, Dana 300 transfer case.
Start a heart transplant mid November with LS1 and SM465 :-)
Has anyone swaped a SR4 for a SM465 on a 1980 CJ5 4 cyl?
If so what throw out bearing did you use?
Novak makes an adjustable throwout bearing for AMC engines. It is their part # TB2 and is about $100 on their web site.
You could also check this link for a list and sizing chart: Bearing Chart
Thanks for the link,
I will have to talk with Jeff at Novak again, he was the one that said there were several lengths of throw out bearings.
The 4 cyl Iron duke is a GM motor and the SM465 is a GM Transmission . He mentioned I could use the same stuff except the throw out bearing.
"The 4 cyl Iron duke is a GM motor"
Got myself mixed up while digging on their web site. Their part # TB1 is the adjustable bearing for GM engines.
Thanks, it is easy to do, they have so much information on their site
$210.00
  100.0%
